Need New ECU
Just for clarification, the orange box I removed is stamped "Made In USA" and has NO deterioration on the back side.
That said, the blue box seems to be getting the most nods. I have found these (just to name a few). Any preferences/differences?
P.S
RPM is not an issue. I never run it that high.
I REALLY appreciate all the help, info and offers. Keep 'em coming.
Best price. $17 - free shipping
https://www.ebay.com/itm/Ignition-C...sh=item1f14648055:g:hAoAAOSw3utY5p07#shpCntId
Jegs $35
Modern Electronics with Mopar OEM Appearance
Comparable to Mopar Chrome Ignition Control Unit
7,500 RPM
Made In USA
https://www.jegs.com/i/JEGS+Performance+Products/555/40805/10002/-1
Rick Ehrenberg - Ebay $38 - free shipping
https://www.ebay.com/itm/for-MOPAR-HR7500-Electronic-Ignition-Module-Dodge-Plymouth-Chrysler-MAX-RELIABLE/324236127595?_trkparms=aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=228411&meid=dabf2501a3114792969a336b15a57515&pid=100005&rk=1&rkt=12&mehot=pf&sd=223984333613&itm=324236127595&pmt=1&noa=0&pg=2047675&algv=SimplAMLv5PairwiseWebWithDarwoV3BBEV2b&_trksid=p2047675.c100005.m1851
I got some of the older blue boxes, at least testing never had one fail, now orange and chrome are a crap shoot, usually at higher (5000) rpm they have issues.
THIS - Sorry for the long post
I literally have had ignition issues , maybe fuel issues , maybe valve train issues
LOL
383/432 Stroker - Around 500 HP in my 71 BEE or so i thought
I have commented in more then a few threads about issues around 5,000 RPMs
A lot of it centered around the hydraulic lifters and the Comp XE fast rate cams
Anyways i thought i had it solved when i put my new Firecore distributor in this summer , and that took care of my occasional misfire at lower RPMs and so i thought higher
Yes the older factory distributor had wore out shaft bushings
Then i went to fuel pressure
So i taped a fuel pressure gauge to my windshield - Never dropped below 5 psi when the engine would start missing around 5,000 Rpms
Here is the kick in the ***
Four Ignition Modules - Yes Four
My twenty year old Mopar Chrome 4120534 (Car started , idled , never an issue honestly)
Some old orange generic box from Mancini Racing
A Borg Waner Made In The USA from years ago , brand new in the box that was collecting dust
And now a Standard LX101 brand new in the box that a friend gave me
ALL OF THESE WOULD MISS OR FAIL AT EXACTLY AROUND 5,000 RPMS
Confirmed with Timing Light ran to the inside of my car
Was ready to pull the trigger on a MSD Streetfire or Pertronix Digital HP
Had a Pertronix RTR Distributor , would not fit with Edelbrock Heads so i returned it
Until last week when i received Ricks HIREV 7500 Ignition Module from another friend to try
What the hell i said
And and and - I forgot what it was like to spin a 383 past 5,500 RPMs AGAIN - Night and day honestly
Not a promotion - Just pissed off at myself for not trying a different ignition system all together a few summers back - Keep that factory look bullshit.
And had the RTR distributor that would not fit
Anyways - Literally four different brand ignition modules , all failed above 5,000 RPMs
HIREV7500 seems to be a good option. I used for a couple of weeks while my revnator was coming and is at this moment my spare one BUT a friend of mine got one and just last long 3 months
Plenyty of good out there if you want it. Just have to spend once!
what?????
OK
Spill the beans - Spend Once On ?
I have read some good arcticles on testing different ECUs
Dunnick Racing did some testing I think
Canister coils and ECUs , but that was many many moons ago
I am still tempted to get rid of the whole system and go CD Ignition especially after what I just went through
P.S
Jegs $35
7,500 RPM
Made In USA
Another - Summit Racing
https://www.summitracing.com/parts/sum-851021
question for those guys that have the Rev n ator do you use the coil they suggest or just whatever one u want ?
I'm using Blaster II
well, my car is dissasembled since 2013, and I already had the chromed blaster II coil. On those days, the R/T garage still didn't have a "suggested coil" for his Rev-N-Nator. I got the firts batch they released. Mine is the #20 on SN
Back to post #21
"That said, the blue box seems to be getting the most nods. I have found these (just to name a few). Any preferences/differences?"
I've been running a Street fire for about 6 years now. It works well. I actually had to dial back the timing when I installed it because I got predestination.
What the hell is predestination
LOL - I always wanted to travel back in time
Pre Ignition Detonation - That sounds better
Anyways what distributor you running with the Street Fire ?
Just picked up a blue box from summit, rated at 5500 $30. Thinking all my issues are due to that dam mopar ecu. Says USA on it but not made in.....we’ll see.
90DC2951-100C-4824-9B55-A01D66E41776.jpeg 5AEF4AE5-DC06-487E-A3A3-A4CFA08AFE8C.jpeg
I have gotten blue boxes that the harness won't go on because the plastic surround is too thick.
