L.E.D. Dash Lights and other lights
Red63440
1:24 PM
NY
Can you fill me in on changing my lights over to L.E.D., the pros and cons...?
https://www.superbrightleds.com/mor...edge-retrofit-car/206/6773/#/attributes/10831
The 3Ks look like originals, I tried the 4.1Ks they look a bit too blueish.
Would work in a 1964 Plymouth dash?
Not sure if yours are are the 194, I bought mine off of ebay,Amazon. I went with the green as I don't like white light at night, bothers my vision.
As for any other exterior Leds you would need to buy a different flasher, or else you will get a hyper flash due to the lack of current pulled by the LEDs.
I recently changed ALL my lights (except headlights) over to LED's (can't find them yet). SuperBright has all of them. Worked great and the results were awesome! I used the whitest ones (like 5000K if available). My interior lights looked very yellow before are extremely bright now without changing my lenses.
Octane lighting has headlights with Halo rings for the 65 coronet, installed on mine. Also customized the dash with new gauges, green lights to match the exterior. Be sure to get the relay harness for the lights to avoid the flickering you will get with Halogens.
