Turbobus
Just an FYI, the Milodon pan listed for a 73/74 charger big block on Classic Industries site will not fit. When installing the engine you might think the motor mounts may be a little snug but you can get the motor mount bolts in. You will find out later that the front part of the oil pan is hitting the Back part of the K member. The problem is that where the oil pan begins its transition to the deeper part of the sump, the correct pan is almost a 90 deg transition to clear the more square K member of a 73/74 car, The Milodon pan is angled somewhere around 60 degrees, plus it’s not flat. Once the engine is wedged in, the damage is done! Not very happy with classic, explained the problem and all they would say is” it’s damaged, we can’t take it back” Well, all I can say is you shouldn’t advertise that it fits a 73/74 charger! I’ve spent over 14k with them in the last 2 years !!!! They kind of made it right for me, they gave me some extra discounts, but that doesn’t make it any better for people who ordered that pan and expect it to fit.
