radiator size
davek
2:07 PM
columbia SC
I read this on moparts.com is it true?
Re: Why do i have a 22 inch radiator core in 69 Bee? [Re: cjs69mope] #543327 12/02/09 08:04 PM
Dans 68
member
Los Altos Hills, CA
Nope - standard equipment in a 383 2-bbl or 4-bbl and a 440 auto (no A/C) in '69 was the 053 22" radiator.
Because you don't have an axle package... 3.23's got 22" radiators
I have a 22 inch opening but a 26 inch radiator is in it. So are they saying only 440-6 and hemi got the 26 inch radiators?
I noticed that the 22 radiator upper hose in on the drivers side and the 26 radiator upper hose is on the passenger side.
Is that the factory radiator or after market, does it run hot,here in s carolina it gets smoking hot and humid. I want to install a 22 inch.thanks Dave
Factory rad., never gets hot. Had it out in 90+ degrees. Any hotter than that and I overheat.
Engine has higher than stock compression (185 cranking pressure).
465 hp, 512 torque, VP 110 octane. fuel.
