PRHeads
- 6:52 AM
- Aug 31, 2018
- So. Burlington Vt
Here’s one locally that happened recently.......
Third time around for a build that ate bearings the previous two times.
Cooked bearings the first time, second time they caught it before the bearings turned color.
For the third try they have a machine shop correct the clearance issues and assemble the long block.
Install motor in car....... it’s running at idle for about 5mins....... engine starts to skip...... valvetrain gets noisy..... they shut it off.
Pull the covers...... a couple of valves are stuck open.
I had gone through the heads prior to the first go around, and they survived two sessions on the dyno without issue.
They changed to different rockers that had no feed holes to the valves.
I told him I didn’t like that, but didn’t feel it was the cause of the stuck valves.
He was pulling the heads to bring them over for a look see.
I get a call a few minutes later...... they found the issue.
No one put coolant in it.
Sure enough....... stuck some valves.
I replaced the guides on the stuck ones, touched everything up, and sent them out the door.
There was a discussion about pulling the motor or not, and replacing the rings as a precaution.
The decision was made to try it without pulling the motor, so no new rings.
It smokes now.
It smokes now.
There was no one else in the shop. He said Jim fired everyone at the end of 2018. That was right after I picked up my short block. Ray said he was off sick for two years, but came back when Jim fired everyone.
