FOUND 1970 Steering Column Parts
72ls5fla
3:43 AM
Tallahassee, FL
Feedback: 19 / 0 / 0
Hello -
Need the following:
1. the (2) "C" clips/snap rings that go before and after the lockout ring plate on the steering
shaft
2. Used ignition switch that has good connections at the switch and plastic end connector is in
good shape.
3. a used/decent turn signal switch that is correct for 1970 and has a good plastic end
connector.
Thanks - Bill
Hello -
Need the following:
shaft
good shape.
connector.
Thanks - Bill
Hello Bill,
I think I can help you. Do you still need everything listed?
