Paint question
Bold & Old
Deceased, But not forgotton
10:02 AM
someware
I am trying to beat the cold weather in Michigan and know that below 65 degrees is the cut off as far as spraying paint.
I want to use spray cans of Rustoleum sandable primer on the underside of the floor pans.
I will be using the urethane base coat paint over that primer on bare metal.
I am also using clear engine enamel over the base coat... because i want to have a thinner look.
The urethane clear has a thicker heavy look when dry. I believe it would be easier to use cans then a spray gun.
I called Rustoleum headquarters for clarification. They told me I could use there sand-able filler primers.
I know that at one time they used fish oil in there products.... they told me that they do not use fish oil since 2005.
I would like some feedback and suggestions about what i am about to do.
Thanks for any and all input....:)
I would definitely do a test panel on what you plan on doing. Rustoleum doesn't always play nice with other brands.
You're going to need one hell of a strong finger if you plan on using spray bombs. Personally I would use a epoxy primer and top coat of the same brand. Shoot your paint with a spray gun, use the fastest drying thinner, air out the shop and turn on the heat. If you don't have a shop, pick a sunny day. You're just doing the underneath right?
Yes sir..... I am only doing firewall and underneath for color purposes... where the engine and transmission will sit. I will be able then slide my elephant & 4spd this winter...
Next spring I will get the clear urethane coat for the top side for sure when i paint the car.
I will also do a compatibility test to confirm it will stick.
The clear urethane covers to much detail..... more than i would prefer + the clear is more resistant to heat near the engine.
Who ever painted my car last....... left it I do not like the inside crimped door skin edge filled way to heavy or thick.
Clear urethane has a time element or pot life.... where the base coat does not. I have used urethane before with great success.
Thank you again friend.
FYI
The spray bomb Rustoleum sand-able filler primer works well with urethane base coat.
According to me and myself.... :thumbsup:
