biomedtechguy
Accelerati Rapidus Maximus
- 1:52 AM
- Mar 28, 2014
- South Louisiana
The only electric fan and shroud assembly I have is the 17" single fan, 2 speed motor.Do you have a photo of your fans? I could bring you the low profile dual fans from my Charger if they would interchange.
I wouldn't even hook up a (3rd) fan motor to my current wiring array, because something is causing the fan motor to burn up. I don't know what the cause is, and I shouldn't HAVE TO be figuring this **** out, BUT I'm glad I have the capability to do so.
I sure thought I had the cause of the 1st fan motor burning up figured out. Car at shop that did install, ran 30 minutes in the shop w/AC on, no problem. I drive in traffic and 5 school zones 15 minutes on a hot day to the alignment shop the day I picked the car up, no problem. I drive straight to the Interstate at 40 MPH, at night, lights on, a couple of red lights, no problem. I get on the Interstate, drive an hour at 2,750 RPMs, lights on, monitor fan via Dakota Digital PAC-2800BT electronic fan control module app, no problem. Drive 15 minutes on the street to get to the "swamp road" no problem. Turn my high beams on and w/in 5 minutes, trip the 200 amp breaker, which kills all power to the car, check under the hood, smell tell tale electric burning smell and see smoke coming from the fan motor...BIG PROBLEM. I waited a few minutes, reset the 200 amp breaker, turned the key on to power up the Dakota Digital fan control module, reset all parameters to high temps, etc to try to keep the fan off, and make it home about 4 minutes away. Temperature of my cooling system WAS FINE the whole trip!!
So I figured I have a high current draw in my headlights, because my windshield leaked BAD because it only had the rubber trim seal to keep water out when I first got the car, and I had that fixed right away, but water poured out under the dash by the firewall on my feet, and my headlights were always dim, at idle, with the relatively low amp factory alternator. Now I have a 140 amp alternator, so my headlights are bright, but surely the dimmer switch must be corroded from the leaky windshield, making the lights, especially the high beams, draw too much power, and that made too much voltage go to the fan and burned it up...RIGHT?
WRONG!!
Now I don't know WTF the cause is?
