JG1966
Thanks RT. Yeah, I had to loosen everything to get idler arm loose so I'm changing all the boots while I'm in there. When I put idler arm back in the K frame "ears," without the bolt, how snug should it be between the ears? I have a little gap. A 3/32 inch thick washer won't fit. A 1/16 will probably fit. I also noticed it took a lot of effort to swing idler arm back and forth when it was bolted in there and torqued down. It was by no means free and easy (if it's even supposed to be).I would just disconnect the center link from the idler and see how much play it has. Shim as needed and reassemble. Unless you are taking all the other stuff apart to check for piece of mind?
BTDT
