Ski 61701
- 12:07 PM
- Nov 21, 2016
- Bloomington Illinois
Evan, you should not have to drill any holes in your butterflies. We are explaining what some people do to try n doctor things up to get them to work.
Id take carb off to really clean out the float bowls and to make sure your jets are free n clear of debris. once carb is off just rotate to see the idle screw slots on inside of venturis are covered by butterfly when they are closed. If you see the idle slots when butterflies are closed, you need to monkey with timing. As Bob mentioned make sure the carb base gasket does not cover up any idle passages on base of carb, and make sure intake manifold if it has any vac ports on carb mount arent covered up. Its so you dont chase your tail trying to tune the motor.
once you do get it running, put a vaccum gauge on the one of the vac ports on carb. Again google or you tube how to use vacuum gauge to assist in tuning your motor. You'll find all kinds of neat info you can use by utilizing a vac gauge, if your timing is off, weak valve springs, cam timing, leaky valve seats etc.
