Ratroaster
- 9:57 PM
- Jun 24, 2014
- Bullhead City, Arizona
Where the tabs end up will differ for your specific needs. Make your adjustment, put the timing light on it, check the full curve and re-adjust if needed (I like to use small drill bits to hold the plate in place while tightening the screws).
Bean,
Do you have any info on how much total mechanical advance the Direct Connection
distributors will add if the 2 metal tabs are completely closed ( as in the picture in post # 17 above ). Thanks. RR
