Aluminum heads - paint ‘em or bare or?
These are just a couple of the steps to proper and lasting application of Nylac - and the products don't come in smaller quantities!
this is what I was referring to, I've used it on several aluminum parts and it seals the aluminum to keep it nice from dirt etc.
Looks great!! Any issues with the stock valve cover's on the tf 240's?
Using roller rockers and no problem using the original 69’ valve covers. I heard the reproduction covers won’t clear on the ends when using roller rockers though.
ceramic coated mine helps hold heat in. supposed to help with fuel boiling, excessive engine compartment heat heads are holding up good exhaust manifolds discolored a little during cam
break in period
All aluminum painted..........heads, intake, water pump & housing.
Odds & ends added........
And finally, installed........
