In post #12 your measurement is 2.125".
No sir, the yolks are the same size. I might just have to take it to a drive shaft shopIs it possible this needs some type of conversion u-joint? There are three types of them I think.
That's a 7260 u-joint that comes on small blocks not sure about B or RBs I think?I'm going to try these.
NEAPCO 1-6300
There are only 3 Mopar factory joints. 7260, 7290, and 1330. If one of those doesn’t fit the installation process is incorrect or the inner width of the driveshaft has been bent slightly. I would get someone with real world U joint experience to help you. By the way. Buy a real dial caliper, they’re cheap.That's a 7260 u-joint that comes on small blocks not about B or RBs.
That's a 7260 u-joint that comes on small blocks not about B or RBs I think?
