Back in the day it was sperm whale oil.
Are we still talking about diff oil here?the more it stinks the better it is
Picked up 4 x quarts of Redline yesterday for my new build ...plus a little extra booster if requiredAre we still talking about diff oil here?
I'm heading out tomorrow to collect some Redline oil with friction modifier built in.
Apparently my new sure-grip unit is really aggressive...like super angry. Looking forward to making some black marks on the road.![]()
That diff must be huge!Picked up 4 x quarts of Redline yesterday for my new build ...plus a little extra booster if required
You can get limited slip additive at almost any parts store now.
Name brands like Castrol.
I wanted the gallon pack because it's cheaper....but also not available....so I have some spare now.That diff must be huge!
You are lucky that the little tag was still there. If you didn't know that a limited slip requires different fluid then you would've been in for an unpleasant surprise. Do you have an owners manual and a service manual for your car?I am putting a suregrip in my wife's wagon. It's the first time I ever saw the little aluminum tag that says "Use Sure Grip Fluid". Is there really any difference than standard gear oil or should I use something else?
Yes but the rear end is from a 68 Roadrunner. I picked up a bottle of the Motorcraft stuff. All should be good now.You are lucky that the little tag was still there. If you didn't know that a limited slip requires different fluid then you would've been in for an unpleasant surprise. Do you have an owners manual and a service manual for your car?
My 2000 Durango with a TracLok started chattering at 25k miles and after cleaning out the gunk in the rear and adding fresh oil along with the Ferd additive, it started chattering again less than 5k miles. At least no gunk this time but along with new oil again, a bottle of STP went in and it's been quiet ever since.....well, up until 100k miles and that's when the wife leftI was installing a used sure grip chunk and did an internet search for additives. Saw that some people use STP additive, I tried it, and it worked. Cheap and readily available.
Here ya go...I made it easy for future reference to all here....Simply do a burnout.
You'll know.
