Correct installation of green axle bearings.
Resurrecting the thread. Thinking about the Dr Diff green bearings. Any updates, or new opinions?
IMO....Use the TIMKEN tapered roller bearings installed with the factory OEM style adjusters....and go down the road for miles and miles in complete confidence..... others will disagree and have their own preferences.
BOB RENTON
If you are putting together a complete rear axle from various parts, I would use the greens. Tolerances aren't so important. If you are working on one that has all the original components ( such as the center thrust block and the axle end play adjuster ) I would probably go with the stock timptkin bearings. Just be SURE your axles are within clearance on both sides. ...................................MO
BTW has anyone here drilled and tapped the axle housing for grease zerks , to grease the rear axle bearings? I know years ago, the factory did that, but I think there was problems with people putting to much grease in them . .........................MO
I've never seen a grease fitting on any factory rear at the wheel bearings. Tell me more.
I had a 1956 Chrysler and was in a 1955-1962 finned Mopar forum. IIRC there were a few cars from that era that came from the factory with those grease zerks. Seems to me that it didn't work out so well because people would eventually get to much grease in the bearings and it would squeeze out into the brake drums-shoes..........................MO
Not sure what the purpose would be. The tapered rollers are esentually a sealed bearing. Unless a grease seal fails what would be the purpose of adding more grease.
Yes, that was the problem, lube room guys would hit every visible zerk at each oil change and that's too much grease for those bearings. Eventually, the excess grease would blow out the seals.
Watch for the clip groove and o-ring groove...
So in the picture, the retainer ring on the the green bearing (opposite side if O ring of course) will sit against the brake back plate, correct?? Plate goes on axle housing first, then the axle with plate, green bearing, retainer ring will slide in.
In this scenario the retainer/snap ring will sit against the outside of the brake plate. I'm currently installing green bearings on my 8 3/4 rear. It just dosen't seem right. It appears that a portion the outer race (comparatively speaking) is sitting "outside" the axle.
Please Help!!
I've included pictures, with the bearings NOT pressed on yet because i wanted to make sure of how this would fit together. Just dosen't feel right!
Please Help!!
View attachment 1041619 View attachment 1041620 View attachment 1041621
Faciously speaking.....its not too late to re-install the origional Timken Tapered axle bearings with the factory end play adjusters. All of your fitmet issues will go away, just follow the FSM procedures for installation and adjustment and you'll go down the road for miles and miles with out any reservations. Just return the Green bearings to the place of purchase for credit. Others will likely have a different opinion. Just my opinion of course.
BOB RENTON
Please Help!!
The ring plate you're holding in bottom pic goes btw the pressed axle end bearing and the end of axle. The outer protruding snap ring is to sit flush to this plate when you slide the axles in, if not, the thrust pin may need to be taken out; wasn't necessary with mine but some have said this needs doing if the axles don't fully seat. Back plate goes over this to torque nuts secure axle. That ring plate needs a gasket
Here's a pic of the location of the plate if I followed your question.
That green bearing with the nicely painted rear isn’t in the axle flange all the way. The bearing will stop on the backing plate at the snap ring.
Right, I was just holding everything up there for sequence visual. I was trying to visualize the setup before having the bearing and the collar pressed on. It just didn't seem right to pinch that snap ring on the bearing between the brake back plate and the 5 hole retaining plate. I have since had email contact with Dr. Diff. They said the heavy felt pad they provide is to go between the brake back plate and the 5 hole retaining plate. Otherwise the 5 hole retainer ring would bend over the snap ring.
It also appears when that (snap?) ring bottoms out against the brake plate a portion of the bearing race will be protruding beyond the axle body. That also bothered me but I guess the area protruding out has no load on it. The bearings are set more inside the axle tube. Just thinking out loud.
Don’t forget, You must use the special gasket between the brake backing plate and 5-hole wheel bearing retainer Otherwise the retainer will bend over the snap-ring.
