F 440 assembly date help
SPAULDO
12:39 PM
N.E. MINNESOTA
Can anybody tell me the build date on this pad? 1 14 there’s also an upside down B
January 14th....
this is typically whats found on the ID machine pads:
Diamond=..................0.008" oversize tappets
Maltese Cross=...........0.001" undersized crankshaft
Maltese Cross + X=......0.010" undersized crankshaft
A=............................0.020" oversize cylinder bore
B=............................0.010" undersized main/rod bearings
E=............................cast crank
H=............................standard 4bbl
HP=..........................high performance
HP2=.........................high performance second shift
LC=...........................low compression
OS=..........................0.005" oversize valvestem
P=............................premium fuel
R=............................regular fuel
S=............................special engine
PT=..........................Trenton assembly plant
T=............................Trenton assembly plant (400 & 440 only)
WT or TW=................water test
X=............................oversized valvestems
If that is an F it would be Jan. 14th 1970. If it is an E it would be same date 1969. B means .010" undersize rods and mains, according to my info.
I have a 70 Super Bee built on April 6th 1970. Would this block be era correct if my car was a 440 six pack car?
It's close.... I've seen many closer & a few much earlier....
What does the VIN stamp on the oil pan rail say? If the VIN stamped on the block matches the car VIN then it is the correct block. The date code is in the general range but the only thing that matters is the VIN. If the VIN matches then nobody cares about the date.
Everything you want to know about Mopar engine blocks.
http://www.moparts.org/Tech/Archive/motor/36.html
http://www.440source.com/blockinfo.htm
1965 - 1971
In '65 the third digit of the CID was added to the engine ID code.
After '65 a typical engine ID code will look like this: B383-322
The first digit identifies the year: B=1966
The next 3 digits are the engine CID: 383=383
The last 3 digits are the date and month: 322= March 22
Year Codes for B & RB Engines
  • A - 1965
  • B - 1966
  • C - 1967
  • D - 1968
  • E - 1969
  • F - 1970
  • G - 1971
  • H - 1972
  • J - 1973
  • P - 1960
  • R - 1961
  • S - 1962
  • T - 1963
  • V - 1964
  • 4T - 1974
  • 5T - 1975
  • 6T - 1976
  • 7T - 1977
  • 8T - 1978
Other Stampings
Additional stampings may be found on the ID pad.
They identify non standard engine components.
A - .020 oversize cylinder bores
Diamond - oversize tappets
E - Cast Crankshaft
HP - High Performance
L or LC - low compression
M - .001 undersize main bearing journals
Maltese Cross - .001" undersized bearing shells
Maltese Cross and an X - .010" undersized crankshaft
O.S. - .005 oversize valve stems
P - premium fuel
R - regular fuel
RX or MX - all main or rod journals .010" undersized
S - special engine
WT or TW - water test
X - .010" undersize crankshaft
1965 - 1971
  • A - 1965
  • B - 1966
  • C - 1967
  • D - 1968
  • E - 1969
  • F - 1970
  • G - 1971
  • H - 1972
  • J - 1973
  • P - 1960
  • R - 1961
  • S - 1962
  • T - 1963
  • V - 1964
  • 4T - 1974
  • 5T - 1975
  • 6T - 1976
  • 7T - 1977
  • 8T - 1978
Other Stampings
E - Cast Crankshaft
P - premium fuel
R - regular fuel
S - special engine
And 1964 was V
