Is the following cross ram intake (2402728) compatible w/ 1962 413?
Gold Duster
3:39 PM
Mora, MN
I bought a 413 out of a 1962 Imperial and want to build a max wedge clone out of it. Is the following cross ram intake (casting number 2402728) compatible? Thank you!
Casting # says 63 Max performance II. Your heads might matter.
You'll need a set of Max Wedge Heads to match the manifold. Your heads will not match up. I believe some newer heads are available for that ? I got lucky with my Builder, and He set me up with all the matching pieces to build a "Killer Mill"...
Thank you very much for the information!! That is exactly what I am looking for my 62 Savoy.
Here's a pic of the port difference, MW gasket on standard ports.
I am in the same situation, I have a 413 and would like to put a cross ram intake on it...how about the 440 cross ram intake from A&A, is it more friendly to a somewhat stock port / runner head? Any info would be great... do not want to get the wrong intake.
