Alternator spacer dimensions?
sloinker
2:58 AM
Wyoming
Can't find mine. They are available in the aftermarket but I only need the spacers and don't want to, unless I have to, spend $35 dollars on just them.
Does anyone know the dimensions offhand? Diameter and bolt hole size and the lengths? I figured I could build my own given the correct dimensions.
RB without air conditioning. Specifically 1966 440 that came from Monaco.
I can get them tomorrow, Or next year whichever comes first! I have them written down in the garage. Easy enough to make them.
Top pivot bolt
Long spacer between alt ears 2.35 long
Short spacer between alt and head 1.56 long
bottom bolt spacer is 1.13 long
All 3 are just under 5/8” diameter. I put a 5/8” open end wrench over them and it has little clearance but will barely pivot side to side. So like about .050 smaller than .625” diameter.
Cool! I will build some tonight at work. You Sir saved me some cash and I Thank You!
