64 dodge instrument question
justjim
1:09 PM
wisconsin
does the voltage limiter on the cluster have to be grounded ?? also looking .
Yes. I believe the volt gauge and fuel level gauge work off the same circuit.
Isn't there a tab on yours welded to the case. One of three spade connection that plug into the printed circuit board. The limiter provides about 5 volts to operate the temp and fuel gauges.
Yes it has to be grounded to work and one of the tabs on it should be the ground. Ron
