67 440 ID Info
MTBRider
3:17 PM
Kenosha WI
I’m trying to understand the details on my 440 and could use some help decoding the info on the ID pad. From info I found on moparts.org I believe the C440 means it’s a 67 440 block but I don’t know what the “iron cross” symbol or the “12” “23” “2” numbers mean.
Any info would be appreciated!
12 December
23 23rd day of the month
2 second shift
Maltese Cross=...........0.001" undersized crankshaft
Maltese Cross + X=......0.010" undersized crankshaft
C440 = 67
12 23 = build date 12/23/1966
2 = second shift
Maltese cross = .10 under size bearings.
There is no HP so it wasn't a high performance engine.
Thanks for all the info!
Just to clarify, .010 inch undersize crank bearings or .100 inch undersize? Any idea of the reason for the undersize condition?
I don't see an X so it's not .010... It is .001..... It's certainly not .100.... And usually it's not all the journals just one or two & that info will be stamped into the front counter weight on the crankshaft...
Ok, thanks. Sounds like it’s just because of a mfg tolerance issue and they just stamp to identify it.
.010
Sorry, no... Chrysler would stamp the Maltese cross to inform of a .001 undersize bearing... A .010 undersize bearing was identified with the Maltese cross plus an X....
Thanks I didn't look in the service manual on that one. Memory getting old.
Manual! We don’t need no stinking manual! (well maybe sometimes)
Thanks all for the help
What gives with the two different style font "4"s in the "4 4 0"? Is that common on this stamping pad?
Remember they were stamped. Looks to me to be the same, just one not struck as hard.
:poke: Hay, it was the 2nd shift and was probably tired. I would not mind having it.
Any info would be appreciated!View attachment 1051764
If my eyes haven’t deceived me, it has .20 oversized pistons.
OTHER STAMPINGS:
Diamond = 0.008-in. oversize tappets
Maltese Cross = 0.001-in. undersized crankshaft
Maltese Cross and an X = 0.010 undersized crankshaft
A = 0.020-in. oversized cylinder bore
B = 0.010-in. undersized main and rod bearings
E = cast crankshaft
H = standard 4bbl
HP = high performance
LC = low compression
O.S. = 0.005 oversized valve stems
P = premium fuel recommended
R = regular grade fuel may be used
S = special engine
WT or TW = water test
X = oversized valve guides
https://www.e-bodies.org/resources/...endar-date-code/1969-model-year-engine-trans/
