moper
Factory specs are fine for factory-type expected usage. If they weren’t Mopars wouldn’t be known for their engines. That being said... for more spirited driving or racing you want more space in there, both for oil flow to cool the parts and in case parts deform under use. I’m not sure you are on the same page with your machinist in regard to measuring. The sizes can be presented a couple ways: in thousandths (.***), or in ten thousandths (.xxxx). So “ three thou” is .003, and “thirty ten thousandths” (.0030) are the same thing. In your above post, “three thou” is fine. .0003 (three ten thousandths) is not.
