1 Wild R/T
Will the squirt can method work on a modern car with ABS and such??????
It will work but it won't flush fluid through the ABS valves, just the calipers, lines & master cylinder..
Ok, so a pressure bleeder ( that clamps on the MC) will flush new fluid through the ABS valves and such?? TYIt will work but it won't flush fluid through the ABS valves, just the calipers, lines & master cylinder..
Looks good, never seen anyone use calipers to check the fluid level before...
It's interesting, but how is it better than a length of clear tubing and a box end wrench?Just picked up this nifty tool to aid in bleeding brakes that I found online. It has an O-ring on the inside, so theoretically, it snaps over the bleeder and the fluid would pass straight through it and out the tube with no mess. This one is for 5/16" hex......
I made a power bleeder out of a pump spray bottle from Home Depot, clear tubing and a spare master cylinder capHere is a set with a one way valve so you dont need to use your wife or kid to pump the brakes.
https://www.eastwood.com/ew-3-pc-br...aign=2018-07-25&utm_content=brake+bleeder+set
Best brake bleeding tool for an empty system ever....
Don't even put fluid into the master cylinder, bolt everything together dry then start in the right rear & pump about ten squirts in through the bleeder screw and tighten the bleeder... Then move to the left rear & pump until fluid shows up in the master cylinder...
Then move to the right front... And pump til you just see fluid show up in the master cylinder.... Move to the left front & repeat... Top off the M/C... Go drive the car, your done...
Will that work if there is fluid already in there, just watch for the air to come out?
You need the bleeder screw to put the hose on.Do you take the bleeder out completely and squirt fluid directly into the wheel cylinder or do you attach a hose between the oil can and bleeder?
Yup, like Ed said..
LMAO... and you can determine when they're done as well.. "let me down" !Aw for christ sakes get the wife to pump the fuckin brakes, thats the way its worked forever. At least for me.
Haha, let me down now or you'll get a foot in your ***!LMAO... and you can determine when they're done as well.. "let me down" !
View attachment 1054442 View attachment 1054443
