4 Speed Reverse Harness?
dodge68charger
4:23 AM
Washington
I Converted My 1969 Satellite To a
4-Speed. Just Wondering What Harness Would Be Correct.
I See Year One Lists Two Different Ones For Early And Late Models..
Im Using a New M&H Harness.
Thank You
Thank You
Look at your wiper harness and see if it has a two wire connector. If it does you need the later model harness. If it does not have the connector you need the earlier built harness.
Thank You. I Dont Have a Wiper Motor. I Will See What Year One Has And Get The Equivilent Harness To Match.
Just Not Sure If My Switch Is For a
2 Or 3 Speed Wiper Motor
This is the harness under the hood. Follow it from the motor to the bulkhead and see if there is a two wire connector hanging off of it. That connector is for your back up light harness from the transmission to plug into. If you do not have it the 3 wires from the automatic transmission plugged directly into the bulkhead connector.
If you don't hape wiper motor harness down the hood you can check bulkhead conector down the dash. If it got two white wires ( one of the with a black trace ) arriving to the wiper harness block of wires, you need a late harness.
Here is a 2 speed harness with the connector circled. 3 speed is basically the same. This is the later version.
