Paul_G
- 5:56 PM
- Dec 24, 2013
- Surprise, Arizona
I purchased a Four Seasons heater valve #74643 from Summit racing. Installed it to find that it does not completely stop hot water flow to the heater core. Sent it back, they sent another, and it is the same. In Phoenix we do not need a lot of heat output from the cars heater. These heater valves are blowing hot air out of the vents all the time.
I took off the temp wire to eliminate that from keeping the valve from completely closing. Tied the valve closed with a wire tie. Took the valve off the car, with the valve closed I can blow air through the inlet and feel it come out the outlet.
Is there another brand that works?
