Evan Frucht
I did actually. But oddly enough I think that whatever solvent they used in the random tub of grease I decided to dab my finger in, might have accelerated the wear. Either that or the points that came with new distributor were simply total junk. They did look a little flimsey/cheap and the cam was made out of what looked to be some kind of brown fibrous material... the new napa points have a solid plastic cam... something I noticed..On your points, are you putting a dab of grease under the lip of the points block? this is the space that as the points go over the cam it is constantly getting a tad of lubrication. If you did not lube this area, the point block will wear down pretty quickly. Compare the set you just took off to the new set.
Is your engine wiring harness original to the car? Or has it been replaced?
Dealing with 56 yr old wiring is a crapshoot at best considering these cars were never meant to be on the road this long. Something to think about.
The wiring harness is mostly original but I have redone the bulkhead and replaced all the bad wiring.
