Yes, that would lower the compression by about a point and you could adjust accordingly with the head gaskets.Did you measure the cc on the heads?
You can't just go by published numbers.
If they are really 76 then
I would look for 906 or 452 heads.
. In some applications where you have quench the 516 has its place for pump gas. Sorry, probably not what you want to hear.This matches my experience exactly. I’m 215 @ .050 with 9.25 and just get away with 93. Timing at 36 total mech and another 16 or so of vacuum (for part throttle). Some hot days going up hill at part throttle I get a tiny tick. 89 and it’s a total mess.The cam will help at low RPM. But what about high RPM when it doesn't have time to bleed off cylinder pressure. I can tell you a 214@.050 doesn't like 9.7-1. 906 heads with all combustion chamber depths matched. It has .040" piston to head with KB deflector dome pistons. Polished chambers. Slow curve in the distributor. It'll rattle at 36 total in hot weather.
