- 11:48 PM
- Jan 1, 2013
- Mascoutah, Illinois
Hi all,
I have a question about 440+6 set ups.
Is the fast idle solenoid even necessary for good street-ability? Or was it more for emissions?
I also have a question about the throttle bracket, below in bold.
Car is 4 speed. Not planning on drag racing, maybe once when complete just to do it.
Years ago, approx 1990, I purchased the MP kit minus the manifold, Already had a couple.
I never installed it, got orders to the UK, but am planning to install eventually.
The kit didn’t include the solenoid or it’s bracket.
Kit included:
3 2 BBL Carbs
Throttle cable (for e body / 71-4 B body I think)
Throttle bracket (not sure if correct for manual trans after removing kick down rod) picture same as Mancini bracket pictured below. What does correct original look like?
Throttle return spring & bracket
Carburetor connector linkage
Upper fuel line assembly
Gaskets
Carb base and air cleaner (crappy rolled lip edge on lid one)
Carburetor studs & nuts
Coil bracket
Throttle bracket looks like below
Kit included:
3 2 BBL Carbs
Gaskets
Coil bracket
