Mopar Performance Hemi HELP!
brian.linn
2:17 AM
Conway Springs, KS
I picked up a Mopar Performance 426 Hemi that needs the oil passages drilled. Does anyone have a good recommendation to a machine shop who could do this? I am in the midwest. Thanks!
I had the same problem. The oil galley on the drivers side was only partially drilled. At the time I lived in Abbotsford B.C. and surprisingly I found a local machine shop to do it so hopefully you won't have any trouble getting it done. It did cost me a few hundred dollars but I didn't care.
This doesn't have ANY oil passages drilled.
Ray Barton
224 E. Penn Avenue
Robesonia, PA 19551
Phone: (610) 693-5700
I calculated: 1300 miles, 17 hour drive
OR:
Indy Cylinder Head, Indianapolis IN
There is also a Larry Shepherd, not related to the Mopar Larry Shepherd, that used to come to the Mopar meets years ago. He would be a Hemi guy also and is located in Akron Ohio. I believe web is hemisonly. If not should get you in the ballpark. Hope this helps.
