Absolutely agree!The 17" aftermarket versions of the Mopar Rallye wheel is a great design.
315/35/17 rear w/stock everything at the time and perfectly centered w/NO rubbing. 9x17 w/5" backspace
245/45/17 front 8x17 w/4½" backspace
Thanks KDI would expect a 315 to look too wide on a 9 inch wide wheel. I have 295s on a 10. Yours look good.
BIO, i'm thinking that you'll find those to be too wide for a 9" wheel. The taller the sidewall the more you can cheat on the wheel width to tread width spread but much over 2 difference is pushing it. The 315/35's call for a min. of a 10.5 wide wheel. The combo you have looks pretty sweet as is.Thanks KD
You may know, but those Toyo Proxes TQ drag radials are the first and only tires I've ever used on those Year One Rallye wheels. I took a guess as to what the widest tire in a 17" could fit on the wheels I had just ordered...without rubbing on the car and not looking like they were bulging on a wheel too narrow for the tire.
315/35 specs:
Next tires are I'm going to try the same Toyo Proxes TQ in their 345/40 size. If they don't fit, I'll send them back and get the 315/35. I am a little more concerned about my 9" wide wheel with these, but I have to see how they look mounted.
- Section Width:12.6"
- Tread Width:11.7"
- Overall Diameter:25.6"
According to the specs, the "larger" tire is:
- Section Width:13.7"
- Tread Width:13.4"
- Overall Diameter:27.7"
I appreciate that, and you are probably right regarding "pushing" the cheat on a wider tire or a wheel that is narrower than what the tire manufacturer recommends.The 315/35's call for a min. of a 10.5 wide wheel. The combo you have looks pretty sweet as is.
Also keep in mind the width is measured from inside lip to inside lip so a 9" wide rim is usually 10" overall and a 10" wide rim is 11" overall. Agreed, it does look good.I would expect a 315 to look too wide on a 9 inch wide wheel. I have 295s on a 10. Yours look good.
Thanks, not bad from the GM and Ford viewing angle either...Agreed, it does look good.
I found a few threads but they’re older so I was looking for something a bit more recent.
I’m thinking of going 18/18 or 18/19 maybe even 19/20. Thanks and ideally a 1970 gtx, roadrunner, satellite or Belvedere
here’s the car
Can you please post more pics
Nice looking wheel. I like that color.I got 19s on due to the brembo calipers being so big.
View attachment 1081870 View attachment 1081871 View attachment 1081872 View attachment 1081873
What brand is that wheel and do they make staggered set ?I got 19s on due to the brembo calipers being so big.
ThanksNice looking wheel. I like that color.
They areWhat brand is that wheel and do they make staggered set ?
Interesting I’ve been looking at Ferrara wheels I really like the fr5
