shifter mount NEEDED URGENTLY
RT SE 440
9:02 PM
australia
Hello all i'm in need some urgent measurements as my panel beater is finishing up welding what i need is the measurements of the shifter mount heights as when i put the mounts on the new floor the console in it seems to be too high .so if someone could put a straight edge across on top of the shifter mount and rear mount as pictured and measure from the straight edge down to the seal panel lip this would be much appreciated thanks guys
I took some measurements a while back. Let me see if I can find them.
The heights need to be high enough to compensate for the thickness of the carpet.
The measurements I took were from the rear of the front floor pan where it laps over the rear foot pans to each bracket. But now I can't find those pictures.
I've got the position of the brackets but need the heights as I'm thinking the repop floor pan tunnel is slightly higher which means i have to cut down the bracket a bit hence why i need the height not the position
yes i understand this but the gap looks way too much i don't think carpet and underfelt will make up the gap
