- 11:17 AM
- Jun 21, 2020
- Washington, Michigan
PlymouthDodge or Plymouth? I believe they are different lengths.
YesStill have driveshaft?
What is the difference between the Dana and the moper 8 3/4 rear end with the 4spds length?
Dana 60 should be 50.96"What is the difference between the Dana and the moper 8 3/4 rear end with the 4spds length?
The Plymouths Drive shafts are 50.39 inches
Dodges have a 1" longer driveshhaft and Dana's use a shorter driveshaft than a 8.75.I am not a expert but want to understand...
Dana driveshafts 1966 thru 1971 are the same size for all B bodies?
8 3/4 driveshafts 1966 thru 1971 are the same size for all B bodies?
so why is does your drive shaft have different measurements?
Thank you sir:
Difference between a Dana 60 and a 8 3/4 is 1.14".
Hello sir.... is that consistent with all 1966-71
That's the only number I know about.
