- 10:39 PM
- Jul 1, 2015
The ones i was referring to were the tri-ys, which did have a double exhaust exit, unlike the normal maxwedge exhausts.
As for the normal maxwedge exhausts, i honstly dont know if the will fit in a post 65 car. The engine is moved back a couple inches on the k-member in 66, and i dont know if there is clearance to a double master. There may be, but it will be closer than in a 62-65, and that may be the source of the boiling fluid rumor.
IF one switched to DOT 5 silicon brake fluid in lieu of DOT 3 or 4, should "fix" a potential master cylinder fluid boiling issue....yes....???? Just a thought...
BOB RENTON
