- 4:29 AM
- Jul 17, 2008
- South Jersey USA
helping a friend with his Jeep build, it's an older CJ with a fiberglass tub, and someone made a mess of the wiring. anyway........
simple question, it's been a while: on the starter relay, which is a Mopar relay like the ones in our B's. The "I" terminal gets 12 volts from the ignition switch to trigger the relay and starter, correct? ..... I need to find the wire sending 12 volts with the key in the crank position? thanks!
and does the ground run through the neutral safety switch?
