Gorilla Glue problem potentially solved yesterday . . .
kiwigtx
International Mod of Mystery
Staff member
5:17 PM
New Zealand
I don't know if anyone else here has had problems with Gorilla products?
As some of you are aware, I have been doing my own home renovations for a while now (5 years and counting) ...and I hit upon a potential solution to the Gorilla Glue epidemic sweeping the world by storm.
As a lot of builders or carpenters know, Expanding Foam is a great way to fill small gaps prior to exterior and interior cladding of doorways and framing etc. Over the past few months I have been finishing up a garden shed that I have wanted for many years....and finally got the time & money to complete the deal. Built from Polystyrene insulated Colour-Steel panels, it came together very fast....took about 2 days for me to complete the wall erection on my own. Wife & son assisted with fitting the corrugated roof sections....more about that later. :)
During the process of completing the interior trim angles, I decided to fill the gaps in the mitres with expanding foam....nobody is that good on their first attempt as to not have a few gaps. So I dig out the Gorilla cans and the dispensing gun....only to find nothing came out. After some poking & prodding, and undoing the nozzle, I discovered the foam inside the gun had gummed up, and some had set hard. I wasn't about to go and buy another gun....so I set about cleaning up this one.
Managed to scrape and 'chisel' the hard deposits out with a small screwdriver, but could not flush the sticky foam out of the nozzle. Since I was all out of paint thinners, and I didn't have anything like the recommended cleaning agent to hand....I decided to improvise.
I looked around and saw a can of CRC Brakleen on the bench. I know this stuff stings if it goes in your eyes....did that last week. :rolleyes: So I tried a bit on the nozzle end, and it softened the foam quite fast - and soft enough to remove with a hand wipe cloth. So I got adventurous....and squirted a quantity down the barrel of the gun from the can end....let it sit for a few minutes, and slowly the foam liquified, and started oozing out.
After several more fills & cleanouts, the gun was clean enough to use again. Plopped on a can and tried it out. From a near empty can, I couldn't believe how much foam came out....it was awesome. Managed to get the entire foaming job done, and clean up was easy.
So if CRC Brakleen works that well on the Gorilla Expanding Foam, it stands to reason that all these idiots out there could use it on the heads after using Gorilla Glue. :D
Only one small side-effect.....I noticed that my thumbnail was suffering from what I can only assume is acute dryness and cracking....it will recover in shirt time. That CRC does dry out all the oils from your skin...so please wear gloves :)
:xscuseless:
congrats on the accomplishment
the shed will be spectacular no doubt :asskiss:
& you managed to do all of that & didn't get any
new hairstyle out of it :poke:
or have to go to the Dr. to get it removed
Gorilla?
If it looks like a . . .
E610ADC5-8121-4EDD-8D8A-559948DEF01A.png 0164B212-7647-4A04-B0F0-EE047CDCD2C4.png
use the acetone and pour it down the little can nozzle that you screw on, for expanding foam in a can. Cleans it right up.
Whatever the active ingredient in Brakleen is....it works well enough....and I can use it on my brakes also. :lol:
Brakleen? LOVE the stuff.
Hell, I bathe in it at least once a week. Gets you all squeaky clean.:thumbsup:
(And no, the "enviro-friendly" version don't work worth spit)
For all i know they used Gorilla Glue, super glue, on me, on the long incision they had to do opening me up, and putting my skin back together, after my recent heart surgery.
Apparently you don't get stitched together anymore, but glued back together, with thin surgical tape over the glued incision, until it falls off, or you remove it, after a certain days time frame.
Can't even tell that i got opened up, the incision, is so fine.
Seven inches in length. Top to bottom.
Wonderful things they do, in medical science in this modern day and age.
Came thru the surgery pretty good.
Woke up alive, again this morning. lol
Surgery was done November 30th.
So does this mean Planet of the apes is staying ? But Charlton Heston is leaving?
Btw, Brake kleen is a great inhaler too some folks.
Doubt thats your fist time with poly foam lol.
I tried a few aerosol cans, but they don't last long, and the last one I had - the nozzle snapped halfway through the job. I only use the Pro Gun now...more expensive, but works better.
