joemopar
Hello friends, my 65 Coronet 727 automatic is leaking around kick down linkage. Replaced seals. the shaft seems to have access play. How can I fix this?
Hey, when I change the oil in filter, and add new oil 15w 40 would some zinc additive and send Marvel Mystery Oil, it doesn't get oil pressure for 10 minutes on the restart. I have to start it, shut it off started shut it off many times before I get oil pressure. And I do add oil to the filter, and it's during the warm days so the oils not cold when I add it. Someone told me that I'm losing my Prime but I want to be able to change the world without going through this hassle. I've had the car for a year and I'm change the oil twice and it did it both times. I also unplugged the coil wire so it would not start right away and just crank over the engine thinking that might get oil pressure started. Next time I change the oil oh, I'm going to put 10-30 oil in. Okay guys let me know. Thank you.
You might have seen this before because I put it in for Wecome Wagon not knowing how to do this since I'm a new member for this
