- 12:26 PM
- Apr 13, 2012
- Granite Bay CA
Hmmm.....Another case of loose flex plate bolts. They sure did cause a lot of noise for only being about a turn or two loose. Knocking is gone, I guess that 496 stroker is going to have to wait
You should be thanking these people:
That kinda sounds like a loose flex plate sure sounds external to the engine
That is a floating multiple rattle type noise. A noise not associated with a rod or piston. As mentioned check the flex plate. Also check the crank pulley.
Did you inspect the flex plate? I assume it is an automatic.
Take a cut off broomstick about three feet long and start her up, listening around the motor with it.... you have to lay the one end right against your head, and see which direction it takes you.... it'll be slapping pretty loud in the bellhousing are if its flexplate related.
I had similar issue with a 440 Cuda years ago, same type of sound at idle. It was the flex plate bolts. Ten minutes to fix, what a relief to find that.
