Been following this thread hoping you would find it. I have been fighting the same problem for years and after breaking several 727 tailshaft housing parked it. What are you now using to check angles with and at what locations are you checking them at?
You need a surface perpendicular to the trans center line, I found the best way for me to check them was to pull the driveshaft and go off of the end of the tranny shaft and the pinion yoke (important to hold whatever your using straight up and down). I was going to buy a tool for checking the angle but found an app (clinometer) for my smart phone that works really well and yes I tested it against a level for accuracy (easier to read too). Make sure your checking it with the axle weighted, I've just been putting jack stands under the axle.
I've been told everything under the sun about the subject but it seams 85% agree that your tranny center line and your pinion center line need to be parallel to each other but sometimes it's necessary to point the pinion down a degree or 2 for axle wind up (mines a spot on match to the tranny). I'm just learning this stuff too but there's a video I posted in a thread "why driveshaft angles matter" that clearly shows what causes driveshaft vibrations if your interested. In a nut shell the U joint does not spin in a uniform manner at an angle but pulses and requires a matching or near matching angle on the other end to cancel each other out. They also want to see a degree at both ends to keep the needles moving for longer U joint life.
Drive it. More. When it is dry. I want more confirmation. This angle schmangle doesn't sit. As said, my trans, shaft, motor was shoved in and is smooth. No measuring anything. No shims. Sustain 74 or so and kiss triple digits if safe.
Well my guess is your angles are close enough, maybe they just got lucky? Another thing is my car being dropped 2" makes it a little less forgiving because of the driveshaft being so straight so that's another thing you got going for you?
It was wet and rainy when I tested the driveshaft but today it was dry and sunny when I tested the shims. I only drove it about 5 miles but this vibration wasn't a come and go thing, I knew exactly when and where it was going to do it every time so I'm confident and won't push my luck running the shaft so close to the floor. Once the mods are done I'll update this thread once I put some miles on it but it's a done deal in my book.
Why don't you jack your car up, set the axle on stands, level the car and check your angles? I'd be curious to see where they are.
