David Womby
Background: My 64 Bristol has discs all round. 2 1/8in calipers on front and 1 1/2in calipers on back. It has a dual master cylinder - one line for front brakes and one for rear. No proportioning valve anywhere. Each set of brakes has a remote booster. The boosters front and rear were both 2x boost and the car stopped fine but needed a LOT of pedal effort. So I replaced the front booster only with one that gives 4x boost. The pedal effort is now much more reasonable and the car's braking is quite impressive for a car this vintage and weight.
The question: I tried a panic stop on an empty, straight, dry asphalt road. Car stopped fast and left some rubber behind it. I am sure all 4 wheels locked up. The car stayed pretty much straight throughout but one pair of wheels left darker rubber lines than the others and appear to have started further back along the road.
I would love all 4 to have locked simultaneously but I don't think I can achieve that. How do you know if front or rears locked first? I am guessing the darker line was the fronts as they carry a lot more weight in a hard stop and that line started further back (about 3 yards before the lighter lines appeared) but does that mean the front locked first? Should I worry about which locked first given it stayed straight and stopped well?
Any thoughts would be appreciated.
David
David
