Putting my 69 Charger back together. I am most likely overthinking this. I know the caster and camber need to be correct before the toe is set. My question is on the steering shaft. The gear box is master splined and with the spline in the 12 o-clock the notch on the coupler lines up with it. The upper shaft master spline at the wheel is also in the 12 o-clock position. This is the way it should be all clocked and the individual toes set. Just want to be sure I am correct before I send it out for its alignment.
