Wing It
Hi everyone. I am building a 1970 440 and I have Speed Pro L2355F pistons. On the box it says "Minimum Clearance - .001"" . An older Speed Pro catalog says these pistons should have a minimum clearance of .0015". We called Speed Pro and they stand by these specs although they will not comment on what the maximum clearance is. They told us that if we run .0035" they will likely crack.
I know the piston and skirt design matter as far as how they are constructed. We put the pistons in an oven and measured them hot and they grew about .0035" at 180 degrees.
These pistons are the VMS-75 alloy. Other manufacturers make pistons with the same VMS-75 alloy and they list clearances in the .0025" to .0055" range for a piston about the same size.
The engine is mostly stock for a 1970 440 Super Commando. 906 heads, six pack rods, .060" bore, slightly larger valves, mild hydraulic Lunati cam. Right now we have the block honed to .001" clearance. With only about a half thou on each side of the piston it sure feels tight. My machinist is thinking we might consider .002" - .0025". Has anyone have experience with these same pistons in a 440? If so, what clearance did you run? How long has it been? Any problems?
Thank you!
Thank you!
