Color of my block
max340
4:35 PM
San Diego
Hey guys. What color should my block be painted? blue or orange? 68 Coronet R/T two door hardtop 440. Thanks!
Here's their sales pitch:
BILL HIRSCH ENGINE ENAMELSQUESTIONS AND ANSWERS
WHAT IS THE TRUE TEST OF THE QUALITY OF AN ENGINE ENAMEL?
THE TRUE TEST IS TIME! OF ALL THE ENGINE ENAMELS ON THE MARKET, BILL HIRSCH ENGINE ENAMELS HAVE BEEN ON THE MARKET THE LONGEST. 40 YEARS! AND ENGINES PAINTED WITH BILL HIRSCH ENGINE ENAMEL AS LONG AS 40 YEARS AGO. STILL HAVE THE ENAMEL ON THAT WAS APPLIED 40 YEARS AGO. NO OTHER ENGINE ENAMEL MANUFACTURER CAN MAKE THIS CLAIM.
WHY IS BILL HIRSCH ENGINE ENAMEL THE BEST?
BECAUSE IT IS MADE FROM THE VERY BEST COMPONENTS KNOWN TO MAN TO MAKE A PRODUCT OF THIS TYPE. IT IS MADE FROM THE VERY SAME COMPONENTS THAT ARE USED TO MAKE JET AIRCRAFT ENGINE ENAMEL, A VERY COSTLY AND EXTREMELY HIGH QUALITY MATERIAL NOT READILY AVAILABLE TO ALL PAINT MANUFACTURERS. THE PEOPLE WHO MANUFACTURE OUR ENGINE ENAMELS (UNDER CONTRACT) ARE CONNECTED WITH THE AEROSPACE INDUSTRY. THE ONLY DIFFERENCE BETWEEN OUR ENGINE ENAMEL AND THAT ON A JET ENGINE, IS THE COLOR.
ARE THEIR ANY OTHER DIFFERENCES BETWEEN BILL HIRSCH ENGINE ENAMELS AND OTHER PAINTS SOLD AS ENGINE ENAMELS?
YES, THERE ARE SEVERAL, BUT FOR ONE, IN ORDER FOR A PAINT TO BE AN ENGINE ENAMEL AND STAND UP TO THE HEAT AND TIME LIKE BILL HIRSCH ENGINE ENAMEL, IT MUST BE MADE FROM THE EXACT COMPONENTS THAT BILL HIRSCH ENGINE ENAMELS ARE MADE FROM, WITHOUT ANY DEVIATION WHATSOEVER. THERE ARE NO OTHER ENGINE ENAMELS BEING PRODUCED WITH THESE COMPONENTS AND CONSEQUENTLY NO OTHER PAINT SOLD AS ENGINE ENAMEL, WILL EVEN COME NEAR THE QUALITY OF BILL HIRSCH ENGINE ENAMEL.FOR EXAMPLE. BILL HIRSCH ENGINE ENAMEL CAN WITHSTAND THE MOST SEVERE CHANGE OF TEMPERATURE. IT CAN WITHSTAND A CHANGE IN TEMPERATURE FROM 50 DEGREES BELOW ZERO TO 700 DEGREES FAHRENHEIT IN JUST A FEW MINUTES WITHOUT ANY EFFECT ON THE FINISH. THERE IS NO OTHER AUTOMOTIVE ENGINE ENAMEL MADE THAT CAN MAKE THIS CLAIM. ALL OTHER ENGINE ENAMELS CLAIM TO BE RATED TO 350 DEGREES FAHRENHEIT. BILL HIRSCH ENGINE ENAMEL IS RATED TO 700 DEGREES F. AND IT RETAINS ITS GLOSS.
IS BILL HIRSCH ENGINE ENAMEL RESISTANT TO GASOLINE AND OIL?
YES, UNLIKE THE OTHERS, BILL HIRSCH ENGINE ENAMEL IS RESISTANT TO GASOLINE AND OIL. IT TAKES ABOUT 2 WEEKS AFTER THE PAINT HAS FULLY HARDENED ON THE ENGINE AND CURED FOR THE FINISH TO BE GAS AND OIL RESISTANT. IF THE PAINT IS CONSTANTLY SUBJECTED TO GASOLINE, OIL, AND OTHER SPILLS, THE FINISH WILL EVENTUALLY BECOME STAINED, MUCH LIKE ANY OTHER FINISH, BUT IT HAS FAR MORE RESISTANCE TO GASOLINE AND OIL THAN ANY OTHER AUTOMOTIVE ENGINE ENAMEL.
IS THERE ANY PROOF TO THE QUALITY OF BILL HIRSCH ENGINE ENAMEL?
YES, JUST GO TO ANY CAR MEET WHERE THERE ARE RESTORED SHOW CARS AND IF BILL HIRSCH SUPPLIES THE COLOR FOR A PARTICULAR AUTOMOBILE OR AUTOMOBILES YOU WILL FIND THAT OVER 50% OF THOSE CARS THAT HAVE RE-PAINTED ENGINES, HAVE BILL HIRSCH ENGINE ENAMEL ON THEM. IN THE PAST 35 YEARS, WE HAVE SEEN AS MANY AS 15 COMPANIES MARKET AUTOMOTIVE ENGINE ENAMELS. ALL HAVE SUCCUMBED.
MUST I SANDBLAST MY ENGINE BEFORE PAINTING?
NO, JUST MAKE SURE THE ENGINE IS FREE OF OIL, GREASE OR ANY OTHER FOREIGN MATTER THAT WILL KEEP THE FINISH FROM ADHERING. REMOVE OLD LOOSE AND FLAKING SCALE AND SAND OR WIRE BRUSH THE SURFACE.
MUST I USE A PRIMER BEFORE APPLYING THE ENGINE FINISH?
NOT ON THE BLOCK OR CYLINDER HEAD IF THEY ARE CAST IRON OR CAST ALUMINUM. BILL HIRSCH ENGINE ENAMELS WILL ADHERE BETTER THAN ANY OTHER PAINT SOLD AS ENGINE ENAMEL. HOWEVER, ON STEEL PARTS, SUCH AS OVERHEAD VALVE COVERS, SIDE VALVE COVERS AND ANY OTHER STEEL OR ALUMINUM PARTS, IT IS BEST TO USE A PRIMER ON THEM BEFORE APPLYING BILL HIRSCH ENGINE ENAMEL.
CAN I PAINT THE ENGINE WHILE IT IS IN THE CAR?
WHILE IT IS EASIER TO DO THE ENGINE AND GET A BETTER JOB IF IT IS OUT OF THE CAR, YOU CAN STILL DO IT IN THE CAR. BILL HIRSCH ENGINE ENAMELS DO NOT SPLATTER AND WITH A FAIR AMOUNT OF CARE, YOU CAN GET AN EXCELLENT BRUSH JOB.
CAN I USE BILL HIRSCH ENGINE ENAMEL ON MY MANIFOLDS?
YOU CAN PAINT YOUR INTAKE MANIFOLD WITH IT, BUT NOT YOUR EXHAUST MANIFOLD. THE EXHAUST MANIFOLD GETS OVER 700 DEGREES F. WHICH IS HIGHER THAN THE RATING OF EVEN OUR ENGINE ENAMEL. IN SOME CASES, WITH V-8 ENGINES (IN PARTICULAR BIG BLOCK GM & CHRYSLER ENGINES OVER 350CI)
How do you like it? How well has it held up? How close is the color to factory?
It's done well for me, and I think the color is very good. You can easily brush it on a motor to get every nook and cranny, yet it dries just slow enough to melt every brush stroke into a perfect finish. I would buy directly from POR-15 and likely not bother with Amazon tho. They do have their own direct to consumer online shop. They also have a really good match for the early Orange used in Max Wedges as well. Not knocking Bill Hirsch paints by any means, as I've heard really good things there too, but i've not used them myself.
Here's some Hirsh paint.
I've used POR frame paint, don't let the sun touch it. It failed and fell off. Later, they said in their advertising to cover it with something UV resistant. Thanks, you want to disassemble and sand blast my frame again? I don't. Won't risk buying POR again.
I did my oil pump and fuel pump and water pump in VHT Hi Temp ceramic Wrinkle Black.
So, according to this list, a '69 440-6bbl, meaning with Holleys, would be turquoise.
Turquoise
1964-68 361/383 with Carter
1966-68 440 with Carter
1968-69 383 with Holley
1967-69 440 with Holley
Red
1965-68 273/318/340
Race Hemi Orange
1964-65 426 2x4bbl
Hemi Orange
1966-68 426 2x4bbl
1969 383 with Carter
1969-71 426/440
1970-71 383 with Holley
LOL. Well, clearly thats wrong.
