66 Satellite window crank help
RJS
9:26 PM
new jersey
The crank on my driver's window is overall mint but the knob is floppy. I tried to peen the back to no avail so wondering what do you guys do to fix this??
Maybe I can bring it to my machinist to see if he has any ideas????
Thank Ron
Only draw back to the repro cranks is that they are far nicer than the original castings. I would not waste time with the originals but you could try a Hydraulic press to tighten up the rivet.
If you're really ambitious you can drill out the rivet, tap the knob and replace the rivet it with a hex screw. Years ago, before repos were available, that's what I did. After some adjustments to the length of the screw and a little loctite it worked fine. I have an extra handle I can send you if you'd like to give that a try an see if it works for you. That way you won't destroy your handle test fitting it.
WOW all great information!!!
VFilms I'll keep you in mind.
So far I may have a lead on a good original I'll have to see just how nice it is.
I've been in the hobby since the seventies but never owned a 66 before.
Thank you all very much
Ron
I might have a working original (but I don't think it's mint condition).
let me know if you want me to look for it.
