Linkage
gtx446
6:23 AM
nj
Good Morning,
I have a 66 Charger with Hemi with back to back dual fours.. I am looking for an expert mechanic who knows the 727 and linkage setup for the Hemi. Any help will be appreciated. I live in Central New Jersey.
Thx Vic
Here's a picture, are you missing parts?
Do you have stock return springs? The service manual explains how to adjust kickdown (throttle pressure control really) linkage. Download a service manual from this website, if you have a printer all the better. Believe it's in section 21 trans section. Make linkage it's binding someplace.
https://mymopar.com/service-manuals/
Lube all pivot points. Too stiff a throttle return spring?
Throttle cable kinked/old and fraying inside? Check everything over, shouldn't be overly stiff.
Do you have a hemi throttle cable? It is short. The regular V8 cable will bind of you try to use it, too sharp of bends.
Transmission section is #21
In the factory shop manual they tell you not to lube the kickdown linkage pivot points.
Fixed, can't the ol' memory.
