Road Grabber
- 3:10 PM
- Apr 14, 2020
- Sarasota Florida/NY State
I have this ongoing issue with my 383 4 barrel. I have recently replaced the carb with a fully restored carb that was correct just because I was going to do that anyway. The engine runs fine while revving the engine in the engine compartment. No back firing or hesitation.
When I drive the car it spits at times at acceleration and feels like it's surging and bucking. Only under load does it do this. It does not have a flat spot in neutral. Last year it felt like it was fuel starvation. It almost stalled when cornering. I thought the old carb floats were not adjusted right. I put the car away for the winter and was sent out a for carb restoration until spring. This year engine seemed to run great with the new carb. Idles great. Revving the engine under the hood there is no popping and the secondary circuit works fine.
When I test ride it the car it bucks and pops when you step on the peddle to accelerate. I did add high test (no alcohol always used) to the existing fuel. The old fuel had the additive for storage. I have been tracking this down for some time. I changed the points and cap (dual distributor) and even added a spacer between the carb and a vent line to the fuel line system to prevent percolation.
My next guess is maybe new ignition wires. Any thoughts would be greatly appreciated!
It's annoying driving the car. It doesn't have a smooth acceleration when you speed up.
Thank you in advance!
