66Satellite47
The 3310 should be about as good as you can get for what it seems like your combination is( especially with the secondary metering block). In addition to the vacuum spring you may try changing shooter size a bit and the accelerator pump cam. Of course the main jet size may want a size or two different, but I presume you've done that. 104-105 is a good MPH for upper 12's. What's your gear?
