It sure is. Someone put it in backwards. It has rusted through from the inside. Which means you should replace them all in my opinion.View attachment 1140541 As you can see, it is leaking. Drivers side. Can I fix this?
Drivers rear, see where the starter goes?Driver's side front?
Read post #2 again, different animal.It sure is. Someone put it in backwards. It has rusted through from the inside. Which means you should replace them all in my opinion.
I've seen a lot of stupid things done in my 63 years as a mechanic and electrician. Never underestimate an idiot with a hammer and no instructions.Read post #2 again, different animal.
And try to put a cupped freeze plug in backwards and tell us how good that works.
