What's everybody using what is Lube on door hinges?
Use a dry type lube. Lubes with oily/tacky residue will attract dirt, debris etc... which will cause the door check rollers to freeze up, eventually causing the main pivot springs to fail.
Have questions about Mopar door hinges ?
Ask me before you do anything permanent to your hinges.
Member discounts.
Leo
