Mike Szadaj
- 8:47 PM
- Jan 17, 2019
- St. Clair Shores, Mi
Say Mike where can I find that post.Is it a replacement switch? I put in a replacement switch and I could not manually cancel the turn signal. When I used the signal making a turn it self canceled perfectly.I figured out a fix And it is all explained in a different post.
No not new to older car's. Always tryed to have 60's or 70's vehicles. But now day's have a 2011 ranger ford. 1999 ford F350 diesel 4X4 dually. Well 67 is not that old but young at hart. Love my 69 runner alway's wanted one. Now I have it. Five long years of work on it to bring it back to life. Restored from the ground up. Thanks for the info.Unless you have something retarded going on with your turn signal, it's pretty stout and notches in the "neutral" off position pretty solidly. It's nothing like the turn signals on new cars. Are you a young guy?
If your using the signal to merely change lanes, move the lever enough to operate the signal without going past the catch, then let go when your finished. If you go past the catch, you have to manually push it back past the catch to the released position yourself.
When did touch feature signaling arrive? In my '63, the lever has to be 'engaged' locking the lever to have a signal. Turning the wheel enough trips the signal off or move it back manually.
I had a new repro one years ago and it was quite stiff. Had to apply some grease and work it a bit to get the movement just right.Some of the new reproduction turn signal switches are a bear to hand cancel.
That is the exact situation I had when I replaced my turn signal switch. After instituting the fix I describe, It now functions normally by manually canceling, or self cancelingGrate advice from all. I was trying to get the blinker to come on to pass with out locking it fully in. Have done some test try's an have it figured out I think. The switch dose clear fine when turning the steering wheel. Thanks all.
