- 10:44 AM
- Apr 13, 2012
- Granite Bay CA
My 2007 Ram 1500 has 366,000 miles and still runs great. It uses oil and isn't quite as peppy as it once was but it is still going.
Last year I replaced the radiator because I spotted some crystallized coolant on some of the tubes at the edge of the tanks.
Since then, I still have to add water to the radiator. It doesn't leak when it is running. There is no steam coming from the exhaust pipes. I do notice some wetness under the truck in the morning, no more than a couple of ounces and not every day. I do see A/C condensation dripping sometimes. A week or so goes by and if I don't remember to add water, the temperature creeps up in stop and go commute driving.
Even with it on a car lift, I have never seen it drip from anywhere. There are a few small streaks on the engine block below the heads but again, it is never wet there.
I thought that I could have leaking head gaskets but with no steam from the exhaust and no difference in how the exhaust smells, I can't be confident that there is a leak there.
I guess a leak down test would be a good suggestion. Maybe a cooling system pressure test too.
Any other suggestions?
