PRHeads
- 3:27 AM
- Aug 31, 2018
- So. Burlington Vt
I drove a friend’s Charger that has a sniper and manual trans.
Imo, the root cause of the sensitivity problem at low speeds is the 1-to-1 linkage of the throttle blades.
Converting carbs over to 1-to-1 linkage results in the same feel.
Overly sensitive in the tip in region of throttle opening......... which seems exaggerated with the manual trans.
In an auto with a loose converter, you might not even notice it.
